S32K148-Q176 LPSPI communication
1,087 次查看
carolineliu_wiw
Hello, guys!
Now i 'm trying to do lpspi communication on s32k148q176 EVB. I meet some problems.
I want to use one lpspi as Master,and two lpspi as Slave. so I find one example project "lpspi_dma_s32k148". This example project can do spi communcation successfully, lpspi0 acts as Master to send data, and lpspi1 acts as Slave to receive data. Then I change its configuration. I add one CHIP SELECT pin in lpspi0 “Component Inspector->Properties->Configurations”,also add another lpspi namely lpspi2 as Slave. I try to generate code, it shows many errors. I don't know how to solve it.TAT
Here is my lpspi0-Master Configuration.
Here is lpspi1 Configuration.
Here is lpspi2 Configuration.
Here is lpspi pin Configuration.
Here are errors.
Thanks.
Liu.
596 次查看
Nanettebreaux
The transfer on LPSPI is slightly different from I2C:
• Host will receive 1 byte after it sends out any byte.
• Received bytes should be ignored when host is sending out bytes to target
• Host starts reading bytes by sending 0x00s to target
• The byte 0x00 will be sent as response to host if target is under the following  MyGeorgiaSouthern
1,020 次查看
raresvasile
Please restart S32DS, it will work afterwards.
Rares
