[S32K148] No CLKOUT from SOSC_DIV2
114454338
My setup is not using SDK, but AutoSar package instead.
Now, I want to use CLKOUT pin(PTE-10) to monitor SOSC_DIV2 frequency, but failed.
(If monitor other clock outputs(FIRC, SIRC...), all are no problem, only SOSC, no output generated!)
My SCG registers setting shows below:
SIM registers setting as below:
So, from the Clocking diagram in S32K1xx user manual, I didn't find any mistake.
Could someone support me about this issue? Is there any other configuration I need to check?
Thank you.
dianabatrlova
I'm using S32K148EVB. I tried to set the same clock settings as you and I can measure the SOSCDIV_2 on PTE10 pin without any problem. I attached the simple test code. Please, could you try it on your side?
I hope it helps.
Diana
114454338
Hello, Diana,
I appreciate for your kindly support and I would like to try it as soon as possible,
but unfortunately I'm facing another show stopper issue mentioned by another question. "https://community.nxp.com/thread/515788"
My EVB cannot flash and debug since yesterday...
Could you kindly give me some support how could I fix it first?
Thanks a lot
