S32K148 EVB Rev B freeze while flashing
erdoganguler
I have S32K148 Rev B EVB. When ı try to flash(or debug)  MCU, It freezing  at %61 and holding at %61 about 4 minutes. After that it is done.  MCU works well and also I can debug my code without any problem. But start of flashing or debugging takes about 5 minutes
I tried that with 12 V and also USB power.
Do you have any opinion about this issue?
erdoganguler
I found the solution. ı dont know why , after I stop my virus program, problem was fixed
