S32K148 - ENET TMRn init
1,226件の閲覧回数
jakub_mielczare
What is the correct sequence to properly initialize ENET TMR0 (also 1,2,3) to for capture mode on rising edge? I need pin muxing and ENET register setup sequence with correct values.
Also what is the minimum and maximum frequency of the signal that the timers can work with? What are the values of rise/fall/hold times?
Thank you,
Jakub
タグ(2)
4 返答(返信)
1,085件の閲覧回数
nxp52415
Hello All,
I followed up here with Jakub and the issue he was having seems to be resolved now.
After reviewing Jakub's code, I found that MUX setting for PTE9, which was intended as an "input capture" for ENET 1588 Timer, was set to 4. In the table below extracted from reference manual we can see the intended setting should be 5:
PTE9
PCR_PTE9
0000_0000
DISABLED
Signal Path Disabled
0000_0001
PTE9
PTE
Port E I/O
0000_0010
FTM0_CH7
FTM0
FTM Channel
0000_0011
LPUART2_CTS
LPUART2
Clear To Send (bar)
0000_0101
ENET_TMR3
ENET
ENET 1588 Timer Channel
Confussion on customer site came from the fact that there is no continuity on the values of the table. i.e. it jumps from 3 to 5.
1,085件の閲覧回数
veronicavelciu
Hello Jakub,
I recommend using S32 Design Studio for ARM together with the S32 SDK. You can start from the enet_loopback example and you will be able to configure the pins and the ENET timer through the graphical interface. In order to enable the timer channel, you will need to add the following code sequence:
ENET_DRV_TimerInit(INST_ETHERNET1, &ethernet1_TimerInitConfig);
ENET_DRV_TimerEnableChannel(INST_ETHERNET1, 0U, &ethernet1_ChannelInitConfig0);
ENET_DRV_TimerStart(INST_ETHERNET1);
You should be able to use the Timer 0 channel on the S32K148 evaluation board.
Veronica
1,085件の閲覧回数
jakub_mielczare
One more question: is it possible to test ENET timer capture mode on S32K148 evaluation board (S32K148EVB-Q176)?
1,085件の閲覧回数
jakub_mielczare
Can anyone answer, please? This is urgent.
Jakub
