hi,
i use the s32k146 MCU,when i run the code MSCM->OCMDR[0u] |= MSCM_OCMDR_OCM1(0xFu);
because i want Erase the pflash ,so i want to disable the P-Flash data and instruction speculate & prefetch function.
but it will stop in here ,the mcu wes die in this line,need to restart.
then ,i debug step by step ,is ok,not any problem.
what is the reason about this?
thanks
