S32K144 demo板使用S32KDS开发,Flash操作一直重启
wangchao5128
每次运行到这里,就重启。使用Jlink下载到Flash运行。
dianabatrlova
At first, I would like to ask you to write your question in English to avoid misunderstanding in translation.
It seems that you have modified the available project, so I assume that issue is due to your modifications. Also, can you elaborate on what exactly happens? I assume that you will see an error in the FTFC -> FSTAT register. Can you check it?
Can you share your project?
Thank you.
Diana
