Hello:
My solution is S32K144+UJA1169, when power on, UJA1169 works in normal mode and can transmit message.Then after a while, I change it to stand-by mode and the message stop transmit. After another while, I change it to normal mode but cannot transmit message. Only when I initialize Flex-CAN module at the same time, it can continue to transmit message. Could you tell me the reason and whether it's normal or not?
Thanks!
Kyle
