i am newbie in S32K1 Platform
I try to get can-bus communication on S32K144 demo board.
I start with FlexCAN_Ip_example_S32K144 in loopback and change to normal operation and map the CAN0 RX TX pin but nothing out of TX pin.
This is the main code:
Solved! Go to Solution.
there can be several reasons why it does not work. Ideally is to measure TXD/RXD/and CAN bus lines with scope/analyzer and read module MCR/CTRL1/ECR/ESR1 registers to see module status and if any error are detected.
If you do not see anything on TXD pin, common issues are
- pin initialization
- CAN transceiver status. On EVB be sure SBC's CAN transceiver is active. Power EVB by external 12V
BR, Petr
BR, Petr
