S32K144 SCST NMI Test Failure
701 次查看
nn1
when I run the test called m4_scst_exception_test_nmihf, I failed the test.Because the MCU stack an Extended frame, containing the Basic frame and the FP state information,however the code only handles the Basic frame.I try to modify the code to solve the problem,whether this modification is feasible?
671 次查看
danielmartynek
Due to limited resources, we are currently unable to support customers writing from generic email accounts such as gmail.com or qq.com or similar. Please ensure that you use your company email address when communicating with NXP so that we can prioritize your question accordingly. Thank you for your understanding.
