S32K144 GPIO default status power-on moment
chumcu
Hi,  what is the default status of the S32K144 MCU I/O port , at the  power-on moment ?
(High, low, or high resistance)?
Should I set initial value field from Low to High ?
Other options in below picture, what is the recommended setting, when I control the led on and off ?  Thanks.
I don't  want any I/O port work, at the  power-on moment.
I  use  Processor  Expert  in  S32DS For Arm 2.2 Version,  with  S32K144-100EVB board.
petervlna
It is high-Z. You can find this information in reference manual:
Peter
chumcu
Only control  PTD0 on,  PTD15 and PTD16 both Off.
