S32K144: CAN0 and CAN1 communication lost after some packet
Jimmybai
I use one S32K144 EVB's CAN0 and CAN1 to complete CAN's Tx and Rx. The code is based Demo_CAN_S32K144 project. CAN0 send a 8 bytes frame to CAN1, CAN1 receive the frame and verify if this frame is desired packet. If yes, change CAN-ID and send same frame to CAN0. When CAN0 receiver CAN1's reply frame, verify to see if it is the desired frame. If yes, CAN0 send next frame to CAN1, CAN1 receive the frame and verify it......
At first, the code process soomthly. But CAN0/CAN1 tx/rx run about send 5000+ frame, the CAN0 send a frame without a data content. The communication procedure stop. The can device USBCANFD show the last frame is a remote frame, but I don't send remote frame in code. I don't know it is a remote frame or a false frame without frame content.  I attach the last data's waveform and USBCAN device's data log. Thanks.
Jimmybai
Thank you. My version is S32DS for ARM 2.2. Just now I found the root cause and resolve method in website. The Rx_buffCfg/Tx_buffCfg structure can't be set as a local variable in CAN0_Init()/CAN1_Init(), they should be set as gloabl variable. For detail, please find chapter 3.3 in the link https://blog.csdn.net/tao475824827/article/details/106757092
Jimmybai
I runn the code and find in CAN0_Callback_Func()/CAN1_Callback_Func() functions,  the CAN_Receive() always return STATUS_BUSY, not STATUS_SUCCESS. Maybe that's the root cause. But I don't know why this condition happens, can anyone give me some explaination? Thanks.
PetrS
you did not specify SDK version you have.  Note there was some driver fixes over the time, so be sure to have latest one.
BR, Petr
Jimmybai
Jimmybai
I attach the main() function code below:
#define LED1(x)  PINS_DRV_WritePin(PTA,1,!x);//RED
#define LED2(x)  PINS_DRV_WritePin(PTB,8,!x);//GREEN
#define LED3(x)  PINS_DRV_WritePin(PTB,9,!x);//BLUE
can_message_t canX_Tx_msg[10] = {
{.cs = 0U, .id = 0x06, .data = "01234567", .length = 8},
{.cs = 0U, .id = 0x06, .data = "12345678", .length = 8},
{.cs = 0U, .id = 0x06, .data = "23456789", .length = 8},
{.cs = 0U, .id = 0x06, .data = "34567890", .length = 8},
{.cs = 0U, .id = 0x06, .data = "45678901", .length = 8},
{.cs = 0U, .id = 0x06, .data = "56789012", .length = 8},
{.cs = 0U, .id = 0x06, .data = "67890123", .length = 8},
{.cs = 0U, .id = 0x06, .data = "78901234", .length = 8},
{.cs = 0U, .id = 0x06, .data = "89012345", .length = 8},
{.cs = 0U, .id = 0x06, .data = "90123456", .length = 8},
#define Rx_Filter  0x0
char IRQ_CAN0_RX = 0;
char IRQ_CAN1_RX = 0;
char IRQ_CAN2_RX = 0;
char IRQ_CAN0_RX_SUCC = 0;
char IRQ_CAN1_RX_SUCC = 0;
char IRQ_CAN2_RX_SUCC = 0;
uint32_t can0_tx_total_cnt = 0;
uint32_t can0_rx_total_cnt = 0;
uint32_t can0_rx_succ_cnt = 0;
uint32_t can0_rx_fail_cnt = 0;
uint32_t can1_tx_total_cnt = 0;
uint32_t can1_rx_total_cnt = 0;
uint32_t can1_rx_succ_cnt = 0;
uint32_t can1_rx_fail_cnt = 0;
can_message_t recvMsg_CAN0;
can_message_t recvMsg_CAN1;
can_message_t recvMsg_CAN2;
#define RX_MAILBOX_CAN0  (0UL)
#define TX_MAILBOX_CAN0  (1UL)
#define RX_MAILBOX_CAN1  (2UL)
#define TX_MAILBOX_CAN1  (3UL)
#define RX_MAILBOX_CAN2  (4UL)
#define TX_MAILBOX_CAN2  (5UL)
void can_normal_en(int canSn)
if(canSn == 0)
PINS_DRV_ClearPins(PTD, 1 << 9);
if(canSn == 1)
PINS_DRV_ClearPins(PTB, 1 << 4);
if(canSn == 2)
PINS_DRV_ClearPins(PTC, 1 << 11);
void can_silent_en(int canSn)
if(canSn == 0)
PINS_DRV_SetPins(PTD, 1 << 9);
if(canSn == 1)
PINS_DRV_SetPins(PTB, 1 << 4);
if(canSn == 2)
PINS_DRV_SetPins(PTC, 1 << 11);
/*CAN0回调函数*/
void CAN0_Callback_Func (uint32_t instance,can_event_t event,uint32_t buffIdx,void *flexcanState)
(void)flexcanState; //此处防止警报
(void)instance;
(void)buffIdx;
if(CAN_Receive(&can_pal0_instance, RX_MAILBOX_CAN0, &recvMsg_CAN0) == STATUS_SUCCESS)//接收报文并重新注册回调函数
IRQ_CAN0_RX_SUCC = 1;
else
switch(event) //回调事件
case CAN_EVENT_RX_COMPLETE: //接收完成事件
IRQ_CAN0_RX = 1;
break;
case CAN_EVENT_TX_COMPLETE: //发送完成事件
break;
default:
break;
void CAN1_Callback_Func (uint32_t instance,can_event_t event,uint32_t buffIdx,void *flexcanState)
(void)flexcanState;
(void)instance;
(void)buffIdx;
if(CAN_Receive(&can_pal1_instance, RX_MAILBOX_CAN1, &recvMsg_CAN1) == STATUS_SUCCESS)//接收报文并重新注册回调函数
IRQ_CAN1_RX_SUCC = 1;
else
switch(event)
IRQ_CAN1_RX = 1;
break;
break;
default:
break;
void CAN2_Callback_Func (uint32_t instance,can_event_t event,uint32_t buffIdx,void *flexcanState)
(void)flexcanState;
(void)instance;
(void)buffIdx;
if(CAN_Receive(&can_pal2_instance, RX_MAILBOX_CAN2, &recvMsg_CAN2) == STATUS_SUCCESS)//接收报文并重新注册回调函数
IRQ_CAN2_RX_SUCC = 1;
else
switch(event)
IRQ_CAN2_RX = 1;
break;
break;
default:
break;
void CAN0_Init(void)
CAN_Init(&can_pal0_instance, &can_pal0_Config0);
can_buff_config_t Rx_buffCfg =  {
      .enableFD = false,
      .enableBRS = false,
      .fdPadding = 0U,
      .idType = CAN_MSG_ID_STD,
      .isRemote = false
can_buff_config_t Tx_buffCfg =  {
      .enableFD = false,
      .enableBRS = false,
      .fdPadding = 0U,
      .isRemote = false
CAN_ConfigRxBuff(&can_pal0_instance, RX_MAILBOX_CAN0, &Rx_buffCfg, Rx_Filter); //注册接收配置和MSGID过滤器(如过滤器配置为0x1,则只接受msgid 0x1发来的报文)
CAN_ConfigTxBuff(&can_pal0_instance, TX_MAILBOX_CAN0, &Tx_buffCfg); //配置发送
/*设置MSGID的掩码,掩码粗略可以理解为对11bit MSGID地址的过滤
如果某bit位需要过滤设置为1,不过滤设置为0,例如掩码设置为0x7ff则过滤全部标准id,如果设置为0x7fe,这只能接受0x01的报文(不存在0x0的地址)*/
CAN_SetRxFilter(&can_pal0_instance,CAN_MSG_ID_STD,RX_MAILBOX_CAN0,0); //设置MSGID掩码,
CAN_InstallEventCallback(&can_pal0_instance,&CAN0_Callback_Func,(void*)0); //注册回调函数
CAN_Receive(&can_pal0_instance, RX_MAILBOX_CAN0, &recvMsg_CAN0); //*****重点****此函数不只有接收作用 还有续订回调函数的作用.
void CAN1_Init(void)
CAN_Init(&can_pal1_instance, &can_pal1_Config0);
      .enableFD = false,
      .enableBRS = false,
      .fdPadding = 0U,
      .isRemote = false
      .enableFD = false,
      .enableBRS = false,
      .fdPadding = 0U,
      .isRemote = false
CAN_ConfigRxBuff(&can_pal1_instance, RX_MAILBOX_CAN1, &Rx_buffCfg, Rx_Filter);
CAN_ConfigTxBuff(&can_pal1_instance, TX_MAILBOX_CAN1, &Tx_buffCfg);
CAN_SetRxFilter(&can_pal1_instance,CAN_MSG_ID_STD,RX_MAILBOX_CAN1,0);
CAN_InstallEventCallback(&can_pal1_instance,&CAN1_Callback_Func,(void*)0);
CAN_Receive(&can_pal1_instance, RX_MAILBOX_CAN1, &recvMsg_CAN1);
void CAN2_Init(void)
CAN_Init(&can_pal2_instance, &can_pal2_Config0);
      .enableFD = false,
      .enableBRS = false,
      .fdPadding = 0U,
      .isRemote = false
      .enableFD = false,
      .enableBRS = false,
      .fdPadding = 0U,
      .isRemote = false
CAN_ConfigRxBuff(&can_pal2_instance, RX_MAILBOX_CAN2, &Rx_buffCfg, Rx_Filter);
CAN_ConfigTxBuff(&can_pal2_instance, TX_MAILBOX_CAN2, &Tx_buffCfg);
CAN_SetRxFilter(&can_pal2_instance,CAN_MSG_ID_STD,RX_MAILBOX_CAN2,0);
CAN_InstallEventCallback(&can_pal2_instance,&CAN2_Callback_Func,(void*)0);
CAN_Receive(&can_pal2_instance, RX_MAILBOX_CAN2, &recvMsg_CAN2);
int main(void)
int MCU_Freq;
int sendGap = 200;
/*** Processor Expert internal initialization. DON'T REMOVE THIS CODE!!! ***/
#ifdef PEX_RTOS_INIT
    PEX_RTOS_INIT();                   /* Initialization of the selected RTOS. Macro is defined by the RTOS component. */
#endif
  /*** End of Processor Expert internal initialization.                    ***/
CLOCK_SYS_Init(g_clockManConfigsArr, CLOCK_MANAGER_CONFIG_CNT,g_clockManCallbacksArr, CLOCK_MANAGER_CALLBACK_CNT);
CLOCK_SYS_UpdateConfiguration(0U, CLOCK_MANAGER_POLICY_AGREEMENT);
MCU_Freq = delay_init();//初始化delay函数
PINS_DRV_Init(NUM_OF_CONFIGURED_PINS, g_pin_mux_InitConfigArr); //初始化IO
CAN0_Init();
CAN1_Init();
CAN2_Init();
FLEXIO_UART_init(); /*! Initialize Timer 0, Shifter 0 to emulate
* an UART transmitter instance, using:
* FXIO_D2 to generate baud-rate (output disabled).
* FXIO_D1 as output shifter pin.
FLEXIO_100KHz_PWM_init(50); /*! Initialize Timer 1 and FXIO_D0 to emulate PWM. */
FLEXIO_UART("CAN_TX_RX_Demo. MCU Run Frequency is %d Mhz \r\n",MCU_Freq);
can_normal_en(0);
can_normal_en(1);
can_normal_en(2);
CAN_Send(&can_pal0_instance, TX_MAILBOX_CAN0, &canX_Tx_msg[can0_tx_total_cnt%10]);
delay_us(sendGap);
    while(1)
if (IRQ_CAN0_RX)//如果接收到CAN报文会通过串口打印出来
//if(1)
IRQ_CAN0_RX = 0;
if(IRQ_CAN0_RX_SUCC)
//if(1)
if(strcmp((char *)recvMsg_CAN0.data, (char *)canX_Tx_msg[can0_tx_total_cnt%10].data) == 0)
//if(1)
delay_us(sendGap);
can0_tx_total_cnt++;
delay_us(sendGap);
else
can0_rx_fail_cnt++;
else
can0_rx_fail_cnt++;
if(can0_tx_total_cnt%1000 == 0)
FLEXIO_UART("Transmit sendGap=%dus,TxCnt=%d,LastData=<%s>\r\n",sendGap,can0_tx_total_cnt,canX_Tx_msg[can0_tx_total_cnt%10].data);
if (IRQ_CAN1_RX)//如果接收到CAN报文会通过串口打印出来
IRQ_CAN1_RX = 0;
can1_rx_total_cnt++;
if(IRQ_CAN1_RX_SUCC)
if(strcmp((char *)recvMsg_CAN1.data, (char *)canX_Tx_msg[can0_tx_total_cnt%10].data) == 0)
delay_us(sendGap);
can1_rx_succ_cnt++;
recvMsg_CAN1.id = 0x08;
CAN_Send(&can_pal1_instance, TX_MAILBOX_CAN1, &recvMsg_CAN1);
delay_us(sendGap);
else
can1_rx_fail_cnt++;
else
can1_rx_fail_cnt++;
if(can1_rx_total_cnt%1000 == 0)
FLEXIO_UART("Receive sendGap=%dus,RxCnt=%d,FailCnt=%d,LastData=<%s>\r\n",sendGap,can1_rx_total_cnt,can1_rx_fail_cnt,recvMsg_CAN1.data);
  /*** Don't write any code pass this line, or it will be deleted during code generation. ***/
  /*** RTOS startup code. Macro PEX_RTOS_START is defined by the RTOS component. DON'T MODIFY THIS CODE!!! ***/
  #ifdef PEX_RTOS_START
    PEX_RTOS_START();                  /* Startup of the selected RTOS. Macro is defined by the RTOS component. */
  #endif
  /*** End of RTOS startup code.  ***/
  /*** Processor Expert end of main routine. DON'T MODIFY THIS CODE!!! ***/
  for(;;) {
    if(exit_code != 0) {
      break;
  return exit_code;
  /*** Processor Expert end of main routine. DON'T WRITE CODE BELOW!!! ***/
} /*** End of main routine. DO NOT MODIFY THIS TEXT!!! ***/
%3CLINGO-SUB%20id%3D%22lingo-sub-2027543%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K144%3A%20CAN0%20and%20CAN1%20communication%20lost%20after%20some%20packet%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2027543%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20use%20one%20S32K144%20EVB's%20CAN0%20and%20CAN1%20to%20complete%20CAN's%20Tx%20and%20Rx.%20The%20code%20is%20based%20Demo_CAN_S32K144%20project.%20CAN0%20send%20a%208%20bytes%20frame%20to%20CAN1%2C%20CAN1%20receive%20the%20frame%20and%20verify%20if%20this%20frame%20is%20desired%20packet.%20If%20yes%2C%20change%20CAN-ID%20and%20send%20same%20frame%20to%20CAN0.%20When%20CAN0%20receiver%20CAN1's%20reply%20frame%2C%20verify%20to%20see%20if%20it%20is%20the%20desired%20frame.%20If%20yes%2C%20CAN0%20send%20next%20frame%20to%20CAN1%2C%20CAN1%20receive%20the%20frame%20and%20verify%20it......%3C%2FP%3E%3CP%3EAt%20first%2C%20the%20code%20process%20soomthly.%20But%20CAN0%2FCAN1%20tx%2Frx%20run%20about%20send%205000%2B%20frame%2C%20the%20CAN0%20send%20a%20frame%20without%20a%20data%20content.%20The%20communication%20procedure%20stop.%20The%20can%20device%20USBCANFD%20show%20the%20last%20frame%20is%20a%20remote%20frame%2C%20but%20I%20don't%20send%20remote%20frame%20in%20code.%20I%20don't%20know%20it%20is%20a%20remote%20frame%20or%20a%20false%20frame%20without%20frame%20content.%26nbsp%3B%20I%20attach%20the%20last%20data's%20waveform%20and%20USBCAN%20device's%20data%20log.%20Thanks.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Jimmybai_0-1736850821479.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jimmybai_0-1736850821479.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F319506i7D968A87A2AFE0B2%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Jimmybai_0-1736850821479.png%22%20alt%3D%22Jimmybai_0-1736850821479.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Jimmybai_1-1736851134029.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Jimmybai_1-1736851134029.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F319507i7C3EAF1BAD6B0655%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Jimmybai_1-1736851134029.png%22%20alt%3D%22Jimmybai_1-1736851134029.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2029448%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32K144%3A%20CAN0%20and%20CAN1%20communication%20lost%20after%20some%20packet%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2029448%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThank%20you.%20My%20version%20is%20S32DS%20for%20ARM%202.2.%20Just%20now%20I%20found%20the%20root%20cause%20and%20resolve%20method%20in%20website.%20The%20Rx_buffCfg%2FTx_buffCfg%20structure%20can't%20be%20set%20as%20a%20local%20variable%20in%20CAN0_Init()%2FCAN1_Init()%2C%20they%20should%20be%20set%20as%20gloabl%20variable.%20For%20detail%2C%20please%20find%20chapter%203.3%20in%20the%20link%20%3CA%20href%3D%22https%3A%2F%2Fblog.csdn.net%2Ftao475824827%2Farticle%2Fdetails%2F106757092%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fblog.csdn.net%2Ftao475824827%2Farticle%2Fdetails%2F106757092%3C%2FA%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2028868%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32K144%3A%20CAN0%20and%20CAN1%20communication%20lost%20after%20some%20packet%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2028868%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3Eyou%20did%20not%20specify%20SDK%20version%20you%20have.%26nbsp%3B%20Note%20there%20was%20some%20driver%20fixes%20over%20the%20time%2C%20so%20be%20sure%20to%20have%20latest%20one.%3C%2FP%3E%0A%3CP%3EBR%2C%20Petr%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2028708%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32K144%3A%20CAN0%20and%20CAN1%20communication%20lost%20after%20some%20packet%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2028708%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EI%20runn%20the%20code%20and%20find%20in%20CAN0_Callback_Func()%2FCAN1_Callback_Func()%20functions%2C%26nbsp%3B%20the%26nbsp%3BCAN_Receive()%20always%20return%20STATUS_BUSY%2C%20not%20STATUS_SUCCESS.%20Maybe%20that's%20the%20root%20cause.%20But%20I%20don't%20know%20why%20this%20condition%20happens%2C%20can%20anyone%20give%20me%20some%20explaination%3F%20Thanks.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2027965%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32K144%3A%20CAN0%20and%20CAN1%20communication%20lost%20after%20some%20packet%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2027965%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20attach%20the%20main()%20function%20code%20below%3A%3C%2FP%3E%3CDIV%3E%23define%20LED1(x)%26nbsp%3B%20PINS_DRV_WritePin(PTA%2C1%2C!x)%3B%2F%2FRED%3C%2FDIV%3E%3CDIV%3E%23define%20LED2(x)%26nbsp%3B%20PINS_DRV_WritePin(PTB%2C8%2C!x)%3B%2F%2FGREEN%3C%2FDIV%3E%3CDIV%3E%23define%20LED3(x)%26nbsp%3B%20PINS_DRV_WritePin(PTB%2C9%2C!x)%3B%2F%2FBLUE%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Ecan_message_t%20canX_Tx_msg%5B10%5D%20%3D%20%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B.cs%20%3D%200U%2C%20.id%20%3D%200x06%2C%20.data%20%3D%20%2201234567%22%2C%20.length%20%3D%208%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B.cs%20%3D%200U%2C%20.id%20%3D%200x06%2C%20.data%20%3D%20%2212345678%22%2C%20.length%20%3D%208%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B.cs%20%3D%200U%2C%20.id%20%3D%200x06%2C%20.data%20%3D%20%2223456789%22%2C%20.length%20%3D%208%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B.cs%20%3D%200U%2C%20.id%20%3D%200x06%2C%20.data%20%3D%20%2234567890%22%2C%20.length%20%3D%208%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B.cs%20%3D%200U%2C%20.id%20%3D%200x06%2C%20.data%20%3D%20%2245678901%22%2C%20.length%20%3D%208%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B.cs%20%3D%200U%2C%20.id%20%3D%200x06%2C%20.data%20%3D%20%2256789012%22%2C%20.length%20%3D%208%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B.cs%20%3D%200U%2C%20.id%20%3D%200x06%2C%20.data%20%3D%20%2267890123%22%2C%20.length%20%3D%208%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B.cs%20%3D%200U%2C%20.id%20%3D%200x06%2C%20.data%20%3D%20%2278901234%22%2C%20.length%20%3D%208%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B.cs%20%3D%200U%2C%20.id%20%3D%200x06%2C%20.data%20%3D%20%2289012345%22%2C%20.length%20%3D%208%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B.cs%20%3D%200U%2C%20.id%20%3D%200x06%2C%20.data%20%3D%20%2290123456%22%2C%20.length%20%3D%208%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%7D%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%23define%20Rx_Filter%26nbsp%3B%200x0%3C%2FDIV%3E%3CDIV%3Echar%20IRQ_CAN0_RX%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Echar%20IRQ_CAN1_RX%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Echar%20IRQ_CAN2_RX%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Echar%20IRQ_CAN0_RX_SUCC%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Echar%20IRQ_CAN1_RX_SUCC%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Echar%20IRQ_CAN2_RX_SUCC%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20can0_tx_total_cnt%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20can0_rx_total_cnt%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20can0_rx_succ_cnt%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20can0_rx_fail_cnt%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20can1_tx_total_cnt%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20can1_rx_total_cnt%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20can1_rx_succ_cnt%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20can1_rx_fail_cnt%20%3D%200%3B%3C%2FDIV%3E%3CDIV%3Ecan_message_t%20recvMsg_CAN0%3B%3C%2FDIV%3E%3CDIV%3Ecan_message_t%20recvMsg_CAN1%3B%3C%2FDIV%3E%3CDIV%3Ecan_message_t%20recvMsg_CAN2%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%23define%20RX_MAILBOX_CAN0%26nbsp%3B%20(0UL)%3C%2FDIV%3E%3CDIV%3E%23define%20TX_MAILBOX_CAN0%26nbsp%3B%20(1UL)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%23define%20RX_MAILBOX_CAN1%26nbsp%3B%20(2UL)%3C%2FDIV%3E%3CDIV%3E%23define%20TX_MAILBOX_CAN1%26nbsp%3B%20(3UL)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%23define%20RX_MAILBOX_CAN2%26nbsp%3B%20(4UL)%3C%2FDIV%3E%3CDIV%3E%23define%20TX_MAILBOX_CAN2%26nbsp%3B%20(5UL)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Evoid%20can_normal_en(int%20canSn)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eif(canSn%20%3D%3D%200)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPINS_DRV_ClearPins(PTD%2C%201%20%26lt%3B%26lt%3B%209)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eif(canSn%20%3D%3D%201)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPINS_DRV_ClearPins(PTB%2C%201%20%26lt%3B%26lt%3B%204)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eif(canSn%20%3D%3D%202)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPINS_DRV_ClearPins(PTC%2C%201%20%26lt%3B%26lt%3B%2011)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Evoid%20can_silent_en(int%20canSn)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eif(canSn%20%3D%3D%200)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPINS_DRV_SetPins(PTD%2C%201%20%26lt%3B%26lt%3B%209)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eif(canSn%20%3D%3D%201)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPINS_DRV_SetPins(PTB%2C%201%20%26lt%3B%26lt%3B%204)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eif(canSn%20%3D%3D%202)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPINS_DRV_SetPins(PTC%2C%201%20%26lt%3B%26lt%3B%2011)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%2F*CAN0%E5%9B%9E%E8%B0%83%E5%87%BD%E6%95%B0*%2F%3C%2FDIV%3E%3CDIV%3Evoid%20CAN0_Callback_Func%20(uint32_t%20instance%2Ccan_event_t%20event%2Cuint32_t%20buffIdx%2Cvoid%20*flexcanState)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E(void)flexcanState%3B%20%2F%2F%E6%AD%A4%E5%A4%84%E9%98%B2%E6%AD%A2%E8%AD%A6%E6%8A%A5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E(void)instance%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E(void)buffIdx%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eif(CAN_Receive(%26amp%3Bcan_pal0_instance%2C%20RX_MAILBOX_CAN0%2C%20%26amp%3BrecvMsg_CAN0)%20%3D%3D%20STATUS_SUCCESS)%2F%2F%E6%8E%A5%E6%94%B6%E6%8A%A5%E6%96%87%E5%B9%B6%E9%87%8D%E6%96%B0%E6%B3%A8%E5%86%8C%E5%9B%9E%E8%B0%83%E5%87%BD%E6%95%B0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EIRQ_CAN0_RX_SUCC%20%3D%201%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eelse%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EIRQ_CAN0_RX_SUCC%20%3D%200%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eswitch(event)%20%2F%2F%E5%9B%9E%E8%B0%83%E4%BA%8B%E4%BB%B6%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecase%20CAN_EVENT_RX_COMPLETE%3A%20%2F%2F%E6%8E%A5%E6%94%B6%E5%AE%8C%E6%88%90%E4%BA%8B%E4%BB%B6%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EIRQ_CAN0_RX%20%3D%201%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ebreak%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecase%20CAN_EVENT_TX_COMPLETE%3A%20%2F%2F%E5%8F%91%E9%80%81%E5%AE%8C%E6%88%90%E4%BA%8B%E4%BB%B6%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ebreak%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Edefault%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ebreak%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Evoid%20CAN1_Callback_Func%20(uint32_t%20instance%2Ccan_event_t%20event%2Cuint32_t%20buffIdx%2Cvoid%20*flexcanState)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E(void)flexcanState%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E(void)instance%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E(void)buffIdx%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eif(CAN_Receive(%26amp%3Bcan_pal1_instance%2C%20RX_MAILBOX_CAN1%2C%20%26amp%3BrecvMsg_CAN1)%20%3D%3D%20STATUS_SUCCESS)%2F%2F%E6%8E%A5%E6%94%B6%E6%8A%A5%E6%96%87%E5%B9%B6%E9%87%8D%E6%96%B0%E6%B3%A8%E5%86%8C%E5%9B%9E%E8%B0%83%E5%87%BD%E6%95%B0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EIRQ_CAN1_RX_SUCC%20%3D%201%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eelse%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EIRQ_CAN1_RX_SUCC%20%3D%200%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eswitch(event)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecase%20CAN_EVENT_RX_COMPLETE%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EIRQ_CAN1_RX%20%3D%201%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ebreak%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecase%20CAN_EVENT_TX_COMPLETE%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ebreak%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Edefault%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ebreak%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Evoid%20CAN2_Callback_Func%20(uint32_t%20instance%2Ccan_event_t%20event%2Cuint32_t%20buffIdx%2Cvoid%20*flexcanState)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E(void)flexcanState%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E(void)instance%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E(void)buffIdx%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eif(CAN_Receive(%26amp%3Bcan_pal2_instance%2C%20RX_MAILBOX_CAN2%2C%20%26amp%3BrecvMsg_CAN2)%20%3D%3D%20STATUS_SUCCESS)%2F%2F%E6%8E%A5%E6%94%B6%E6%8A%A5%E6%96%87%E5%B9%B6%E9%87%8D%E6%96%B0%E6%B3%A8%E5%86%8C%E5%9B%9E%E8%B0%83%E5%87%BD%E6%95%B0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EIRQ_CAN2_RX_SUCC%20%3D%201%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eelse%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EIRQ_CAN2_RX_SUCC%20%3D%200%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eswitch(event)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecase%20CAN_EVENT_RX_COMPLETE%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EIRQ_CAN2_RX%20%3D%201%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ebreak%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecase%20CAN_EVENT_TX_COMPLETE%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ebreak%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Edefault%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ebreak%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Evoid%20CAN0_Init(void)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECAN_Init(%26amp%3Bcan_pal0_instance%2C%20%26amp%3Bcan_pal0_Config0)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecan_buff_config_t%20Rx_buffCfg%20%3D%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.enableFD%20%3D%20false%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.enableBRS%20%3D%20false%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.fdPadding%20%3D%200U%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.idType%20%3D%20CAN_MSG_ID_STD%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.isRemote%20%3D%20false%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecan_buff_config_t%20Tx_buffCfg%20%3D%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.enableFD%20%3D%20false%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.enableBRS%20%3D%20false%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.fdPadding%20%3D%200U%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.idType%20%3D%20CAN_MSG_ID_STD%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.isRemote%20%3D%20false%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECAN_ConfigRxBuff(%26amp%3Bcan_pal0_instance%2C%20RX_MAILBOX_CAN0%2C%20%26amp%3BRx_buffCfg%2C%20Rx_Filter)%3B%20%2F%2F%E6%B3%A8%E5%86%8C%E6%8E%A5%E6%94%B6%E9%85%8D%E7%BD%AE%E5%92%8CMSGID%E8%BF%87%E6%BB%A4%E5%99%A8(%E5%A6%82%E8%BF%87%E6%BB%A4%E5%99%A8%E9%85%8D%E7%BD%AE%E4%B8%BA0x1%EF%BC%8C%E5%88%99%E5%8F%AA%E6%8E%A5%E5%8F%97msgid%200x1%E5%8F%91%E6%9D%A5%E7%9A%84%E6%8A%A5%E6%96%87)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECAN_ConfigTxBuff(%26amp%3Bcan_pal0_instance%2C%20TX_MAILBOX_CAN0%2C%20%26amp%3BTx_buffCfg)%3B%20%2F%2F%E9%85%8D%E7%BD%AE%E5%8F%91%E9%80%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%E8%AE%BE%E7%BD%AEMSGID%E7%9A%84%E6%8E%A9%E7%A0%81%EF%BC%8C%E6%8E%A9%E7%A0%81%E7%B2%97%E7%95%A5%E5%8F%AF%E4%BB%A5%E7%90%86%E8%A7%A3%E4%B8%BA%E5%AF%B911bit%20MSGID%E5%9C%B0%E5%9D%80%E7%9A%84%E8%BF%87%E6%BB%A4%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%E6%9F%90bit%E4%BD%8D%E9%9C%80%E8%A6%81%E8%BF%87%E6%BB%A4%E8%AE%BE%E7%BD%AE%E4%B8%BA1%2C%E4%B8%8D%E8%BF%87%E6%BB%A4%E8%AE%BE%E7%BD%AE%E4%B8%BA0%2C%E4%BE%8B%E5%A6%82%E6%8E%A9%E7%A0%81%E8%AE%BE%E7%BD%AE%E4%B8%BA0x7ff%E5%88%99%E8%BF%87%E6%BB%A4%E5%85%A8%E9%83%A8%E6%A0%87%E5%87%86id%2C%E5%A6%82%E6%9E%9C%E8%AE%BE%E7%BD%AE%E4%B8%BA0x7fe%2C%E8%BF%99%E5%8F%AA%E8%83%BD%E6%8E%A5%E5%8F%970x01%E7%9A%84%E6%8A%A5%E6%96%87(%E4%B8%8D%E5%AD%98%E5%9C%A80x0%E7%9A%84%E5%9C%B0%E5%9D%80)*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECAN_SetRxFilter(%26amp%3Bcan_pal0_instance%2CCAN_MSG_ID_STD%2CRX_MAILBOX_CAN0%2C0)%3B%20%2F%2F%E8%AE%BE%E7%BD%AEMSGID%E6%8E%A9%E7%A0%81%EF%BC%8C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECAN_InstallEventCallback(%26amp%3Bcan_pal0_instance%2C%26amp%3BCAN0_Callback_Func%2C(void*)0)%3B%20%2F%2F%E6%B3%A8%E5%86%8C%E5%9B%9E%E8%B0%83%E5%87%BD%E6%95%B0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECAN_Receive(%26amp%3Bcan_pal0_instance%2C%20RX_MAILBOX_CAN0%2C%20%26amp%3BrecvMsg_CAN0)%3B%20%2F%2F*****%E9%87%8D%E7%82%B9****%E6%AD%A4%E5%87%BD%E6%95%B0%E4%B8%8D%E5%8F%AA%E6%9C%89%E6%8E%A5%E6%94%B6%E4%BD%9C%E7%94%A8%20%E8%BF%98%E6%9C%89%E7%BB%AD%E8%AE%A2%E5%9B%9E%E8%B0%83%E5%87%BD%E6%95%B0%E7%9A%84%E4%BD%9C%E7%94%A8.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Evoid%20CAN1_Init(void)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECAN_Init(%26amp%3Bcan_pal1_instance%2C%20%26amp%3Bcan_pal1_Config0)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecan_buff_config_t%20Rx_buffCfg%20%3D%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.enableFD%20%3D%20false%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.enableBRS%20%3D%20false%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.fdPadding%20%3D%200U%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.idType%20%3D%20CAN_MSG_ID_STD%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.isRemote%20%3D%20false%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecan_buff_config_t%20Tx_buffCfg%20%3D%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.enableFD%20%3D%20false%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.enableBRS%20%3D%20false%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.fdPadding%20%3D%200U%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.idType%20%3D%20CAN_MSG_ID_STD%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.isRemote%20%3D%20false%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECAN_ConfigRxBuff(%26amp%3Bcan_pal1_instance%2C%20RX_MAILBOX_CAN1%2C%20%26amp%3BRx_buffCfg%2C%20Rx_Filter)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECAN_ConfigTxBuff(%26amp%3Bcan_pal1_instance%2C%20TX_MAILBOX_CAN1%2C%20%26amp%3BTx_buffCfg)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECAN_SetRxFilter(%26amp%3Bcan_pal1_instance%2CCAN_MSG_ID_STD%2CRX_MAILBOX_CAN1%2C0)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECAN_InstallEventCallback(%26amp%3Bcan_pal1_instance%2C%26amp%3BCAN1_Callback_Func%2C(void*)0)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECAN_Receive(%26amp%3Bcan_pal1_instance%2C%20RX_MAILBOX_CAN1%2C%20%26amp%3BrecvMsg_CAN1)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Evoid%20CAN2_Init(void)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECAN_Init(%26amp%3Bcan_pal2_instance%2C%20%26amp%3Bcan_pal2_Config0)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecan_buff_config_t%20Rx_buffCfg%20%3D%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.enableFD%20%3D%20false%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.enableBRS%20%3D%20false%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.fdPadding%20%3D%200U%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.idType%20%3D%20CAN_MSG_ID_STD%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.isRemote%20%3D%20false%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecan_buff_config_t%20Tx_buffCfg%20%3D%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.enableFD%20%3D%20false%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.enableBRS%20%3D%20false%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.fdPadding%20%3D%200U%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.idType%20%3D%20CAN_MSG_ID_STD%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20.isRemote%20%3D%20false%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECAN_ConfigRxBuff(%26amp%3Bcan_pal2_instance%2C%20RX_MAILBOX_CAN2%2C%20%26amp%3BRx_buffCfg%2C%20Rx_Filter)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECAN_ConfigTxBuff(%26amp%3Bcan_pal2_instance%2C%20TX_MAILBOX_CAN2%2C%20%26amp%3BTx_buffCfg)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECAN_SetRxFilter(%26amp%3Bcan_pal2_instance%2CCAN_MSG_ID_STD%2CRX_MAILBOX_CAN2%2C0)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECAN_InstallEventCallback(%26amp%3Bcan_pal2_instance%2C%26amp%3BCAN2_Callback_Func%2C(void*)0)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECAN_Receive(%26amp%3Bcan_pal2_instance%2C%20RX_MAILBOX_CAN2%2C%20%26amp%3BrecvMsg_CAN2)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eint%20main(void)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eint%20MCU_Freq%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eint%20sendGap%20%3D%20200%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F***%20Processor%20Expert%20internal%20initialization.%20DON'T%20REMOVE%20THIS%20CODE!!!%20***%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%23ifdef%20PEX_RTOS_INIT%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20PEX_RTOS_INIT()%3B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%2F*%20Initialization%20of%20the%20selected%20RTOS.%20Macro%20is%20defined%20by%20the%20RTOS%20component.%20*%2F%3C%2FDIV%3E%3CDIV%3E%23endif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%2F***%20End%20of%20Processor%20Expert%20internal%20initialization.%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20***%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECLOCK_SYS_Init(g_clockManConfigsArr%2C%20CLOCK_MANAGER_CONFIG_CNT%2Cg_clockManCallbacksArr%2C%20CLOCK_MANAGER_CALLBACK_CNT)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECLOCK_SYS_UpdateConfiguration(0U%2C%20CLOCK_MANAGER_POLICY_AGREEMENT)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EMCU_Freq%20%3D%20delay_init()%3B%2F%2F%E5%88%9D%E5%A7%8B%E5%8C%96delay%E5%87%BD%E6%95%B0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPINS_DRV_Init(NUM_OF_CONFIGURED_PINS%2C%20g_pin_mux_InitConfigArr)%3B%20%2F%2F%E5%88%9D%E5%A7%8B%E5%8C%96IO%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECAN0_Init()%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECAN1_Init()%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECAN2_Init()%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EFLEXIO_UART_init()%3B%20%2F*!%20Initialize%20Timer%200%2C%20Shifter%200%20to%20emulate%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%20an%20UART%20transmitter%20instance%2C%20using%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%20FXIO_D2%20to%20generate%20baud-rate%20(output%20disabled).%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%20FXIO_D1%20as%20output%20shifter%20pin.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EFLEXIO_100KHz_PWM_init(50)%3B%20%2F*!%20Initialize%20Timer%201%20and%20FXIO_D0%20to%20emulate%20PWM.%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EFLEXIO_UART(%22CAN_TX_RX_Demo.%20MCU%20Run%20Frequency%20is%20%25d%20Mhz%20%5Cr%5Cn%22%2CMCU_Freq)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecan_normal_en(0)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecan_normal_en(1)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecan_normal_en(2)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECAN_Send(%26amp%3Bcan_pal0_instance%2C%20TX_MAILBOX_CAN0%2C%20%26amp%3BcanX_Tx_msg%5Bcan0_tx_total_cnt%2510%5D)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Edelay_us(sendGap)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20while(1)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eif%20(IRQ_CAN0_RX)%2F%2F%E5%A6%82%E6%9E%9C%E6%8E%A5%E6%94%B6%E5%88%B0CAN%E6%8A%A5%E6%96%87%E4%BC%9A%E9%80%9A%E8%BF%87%E4%B8%B2%E5%8F%A3%E6%89%93%E5%8D%B0%E5%87%BA%E6%9D%A5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F%2Fif(1)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EIRQ_CAN0_RX%20%3D%200%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eif(IRQ_CAN0_RX_SUCC)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F%2Fif(1)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eif(strcmp((char%20*)recvMsg_CAN0.data%2C%20(char%20*)canX_Tx_msg%5Bcan0_tx_total_cnt%2510%5D.data)%20%3D%3D%200)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F%2Fif(1)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Edelay_us(sendGap)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EIRQ_CAN0_RX_SUCC%20%3D%200%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecan0_tx_total_cnt%2B%2B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECAN_Send(%26amp%3Bcan_pal0_instance%2C%20TX_MAILBOX_CAN0%2C%20%26amp%3BcanX_Tx_msg%5Bcan0_tx_total_cnt%2510%5D)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Edelay_us(sendGap)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eelse%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecan0_rx_fail_cnt%2B%2B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eelse%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecan0_rx_fail_cnt%2B%2B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eif(can0_tx_total_cnt%251000%20%3D%3D%200)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EFLEXIO_UART(%22Transmit%20sendGap%3D%25dus%2CTxCnt%3D%25d%2CLastData%3D%26lt%3B%25s%26gt%3B%5Cr%5Cn%22%2CsendGap%2Ccan0_tx_total_cnt%2CcanX_Tx_msg%5Bcan0_tx_total_cnt%2510%5D.data)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eif%20(IRQ_CAN1_RX)%2F%2F%E5%A6%82%E6%9E%9C%E6%8E%A5%E6%94%B6%E5%88%B0CAN%E6%8A%A5%E6%96%87%E4%BC%9A%E9%80%9A%E8%BF%87%E4%B8%B2%E5%8F%A3%E6%89%93%E5%8D%B0%E5%87%BA%E6%9D%A5%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EIRQ_CAN1_RX%20%3D%200%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecan1_rx_total_cnt%2B%2B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eif(IRQ_CAN1_RX_SUCC)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eif(strcmp((char%20*)recvMsg_CAN1.data%2C%20(char%20*)canX_Tx_msg%5Bcan0_tx_total_cnt%2510%5D.data)%20%3D%3D%200)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Edelay_us(sendGap)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EIRQ_CAN1_RX_SUCC%20%3D%200%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecan1_rx_succ_cnt%2B%2B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ErecvMsg_CAN1.id%20%3D%200x08%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECAN_Send(%26amp%3Bcan_pal1_instance%2C%20TX_MAILBOX_CAN1%2C%20%26amp%3BrecvMsg_CAN1)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Edelay_us(sendGap)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eelse%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecan1_rx_fail_cnt%2B%2B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eelse%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecan1_rx_fail_cnt%2B%2B%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eif(can1_rx_total_cnt%251000%20%3D%3D%200)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EFLEXIO_UART(%22Receive%20sendGap%3D%25dus%2CRxCnt%3D%25d%2CFailCnt%3D%25d%2CLastData%3D%26lt%3B%25s%26gt%3B%5Cr%5Cn%22%2CsendGap%2Ccan1_rx_total_cnt%2Ccan1_rx_fail_cnt%2CrecvMsg_CAN1.data)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%2F***%20Don't%20write%20any%20code%20pass%20this%20line%2C%20or%20it%20will%20be%20deleted%20during%20code%20generation.%20***%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%2F***%20RTOS%20startup%20code.%20Macro%20PEX_RTOS_START%20is%20defined%20by%20the%20RTOS%20component.%20DON'T%20MODIFY%20THIS%20CODE!!!%20***%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%23ifdef%20PEX_RTOS_START%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20PEX_RTOS_START()%3B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%2F*%20Startup%20of%20the%20selected%20RTOS.%20Macro%20is%20defined%20by%20the%20RTOS%20component.%20*%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%23endif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%2F***%20End%20of%20RTOS%20startup%20code.%26nbsp%3B%20***%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%2F***%20Processor%20Expert%20end%20of%20main%20routine.%20DON'T%20MODIFY%20THIS%20CODE!!!%20***%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20for(%3B%3B)%20%7B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20if(exit_code%20!%3D%200)%20%7B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20break%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20return%20exit_code%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%2F***%20Processor%20Expert%20end%20of%20main%20routine.%20DON'T%20WRITE%20CODE%20BELOW!!!%20***%2F%3C%2FDIV%3E%3CDIV%3E%7D%20%2F***%20End%20of%20main%20routine.%20DO%20NOT%20MODIFY%20THIS%20TEXT!!!%20***%2F%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
