S32K144 Bootloader demo with PLL could not work
已解决
跳至解决方案
2,978 次查看
KILLERzheng
I get the demo from unified bootloader framework, but it could not work with the PLL enable, and when the project init clock, it goes to hardware error. On the other hand, if I set the PLL false, it could works. I do not know where the error is. Besides the EXTAL of my board is 16MHz, is there any wrong with the hardware designing?
标记 (2)
1 解答
2,963 次查看
Senlent
try this configuration.
在原帖中查看解决方案
5 回复数
2,969 次查看
Senlent
Hi@KILLERzheng
This routine uses an 8M external clock crystal oscillator by default. If you use a 16M crystal oscillator, there will be problems. You need to change the clock configuration, or replace the crystal oscillator with 8M. If you don't change the crystal oscillator, you have to change the configuration of the clock part of the BT and APP routines.
2,965 次查看
KILLERzheng
Hi Senlent,
Thanks for you response.
I have not been familiar with PLL configuration, could you please give me some suggestions that how to configure with it?
2,964 次查看
Senlent
2,957 次查看
KILLERzheng
Do you mean that way to modify the configuration?
2,940 次查看
Senlent
Hi@KILLERzheng
yes, please have a try.
