S32K142 LPIT and CLOCK error
Search instead for
Ada_Lovelace
Hi,all
I have a board about S32K142, external crystal is 40Mhz, I config the code referencing the S32K1xx_Clock_Calculator_Rev1.
But when I set the LPIT,I meet the problem:
The code crashs,it does not work. I debug that finding it when I give the value to LPIT, it
debug error, I successfully  run the project when I have the EVB board, which the external crystal is 8Mhz.
What should I do to fix it?Snipaste_2021-08-10_15-12-19.pngSnipaste_2021-08-10_15-13-06.pngSnipaste_2021-08-10_15-22-04.pngSnipaste_2021-08-10_15-22-12.pngSnipaste_2021-08-10_15-22-27.png
danielmartynek
Hello @Ada_Lovelace,
It seems like you use SPLLDIV2 as the peripheral clock.
But is SPLLDIV2 really 40MHz?
With 40Mhz crystal and MULT = 24, Prediv = 0
danielmartynek
