Solved! Go to Solution.
1. What does it mean that the core logic is slower? The processing speed of the cpu will slow down, can it be roughly quantified by how much it will slow down?
- It does not mean that setting of this bit will make the execution slower. It means that this bit can be used only when the execution is slower - in VLPS/VLPR modes.
2. There is a limit to the system clock after it is turned on, what is the limit speed?
- It must be set in VLPS/VLPR modes and cleared in other modes (RUN, HSRUN)
3. This bit configuration is invalid in full performance mode. Does this full performance mode refer to HSRUN or RUN? Or does it have other meanings?
- Yes, it refers to RUN and HSRUN.
Lukas
Lukas
