S32K118EVB Jumpstart with Freemaster
rahulpkumar-2612
I tried downloading the S32K118EVB Jumpstart code from this link: https://www.nxp.com/document/guide/get-started-with-the-s32k118evb:GS-S32K118EVB
But the code that is getting downloaded is for S32K116EVB. Is there any particular reason for the code is for S32K116?
Thank you,
Rahul
Senlent
Hi@rahulpkumar-2612
I just tested the link ,this should be a mistake,and I will report the problem to the internal forum,thank you.
and the S32K118->JumperStart Software link address.
 https://www.nxp.com/search?keyword=JumpStart&start=0&category=software
Note,this demo is too old,you may need to install the old driver version to run this project.
please refer to this article.
https://community.nxp.com/t5/S32K-Knowledge-Base/Q-amp-A-of-S32K1x-FreeMASTER-JumpStart-Project/ta-p...
Sorry for the inconvenience.
BR!
     Jim,
sateesh_kalidas
Hi Jim, @Senlent
  Thank you for the clarity, so the header files indeed is for the S32K118. Please confirm, so we will rename the header accordingly. Thank you.
Sateesh
