S32K118 program debug is OK, but can not run after power-on again
1,713 次查看
happybaby8882
S32K118 program debug is OK, but can not run after power-on again. Please help me!
1,702 次查看
dianabatrlova
Which debug option you use?
Please, select Debug or Debug_Flash in debug configuration, for example:
Diana
1,681 次查看
happybaby8882
Thank you for your reply.
I've tried all the debug settings including debug-flash, it still doesn't work.
