S32K118 chip pflash erase, verify, write
AsaZJP
Hi :
I'm using the S32K118 chip, developing a bootloader, but I'm experiencing a hardware failure interrupt while erasing the pflash, please check if my code is wrong. Thank you
Best Regards
Asa
Senlent
Hi@AsaZJP
It's too much work for us to help you check the bare-metal code one by one.
1.you can provide me your demo code so i can help you troubleshooting.
2.you can refer to this post, have you maped the flash operations to sram?
https://community.nxp.com/t5/S32K-Knowledge-Base/Example-S32K144-Flash-RW-simple/ta-p/1110000
