hi :
there is a question that i had entered into VLPS mode ,but the current Consumption is still 1.2mA,but in S32DS, it could be uA level,i am confuesd how to check ,thanks
Hi @LXD,
Can you disconnect the debugger and power-cycle the board?
With the debugger connected, the MCU cannot enter the VLPS mode but an emulated stop mode instead.
Please make sure the MCU does not drive any external loads on its pins and that no input pin is floating.
Thank you,
BR, Daniel
