S32K116 ADC, TRGMUX, FTM Using
2,439 次查看
종찬박
I want to make peripheral configuration to measure current using ADC with FTM.
my goal is to measure current in DC motor.
as far as I know, I need to use TRGMUX, FTM, PDB, ADC, and connect to each peripheral.
but I can't figure out How to design.
I use the S32 Design Studio for S32 Platform Version: 3.3, S32K116 and SDK RTM 4.0.0.
Can you show me How to design peripheral connection using my tool?
3 回复数
2,426 次查看
danielmartynek
You can refer to MCSPTE1AK144: S32K144 Development Kit for BLDC and PMSM motor control
https://www.nxp.com/design/development-boards/automotive-motor-control-solutions/arm-based-solutions...
Please follow these guidelines:
https://www.nxp.com/document/guide/get-started-with-the-mcspte1ak144:GS-MCSPTE1AK144
Unfortunately, this is built with SDK RTM 3.x.x so you need to use S32DS for ARM v2.2.
AN12435 3-Phase Sensorless BLDC Motor Control Kit with S32K144
https://www.nxp.com/docs/en/application-note/AN12435.pdf
4.1.1.Module interconnection
AN12235 3-Phase Sensorless PMSM Motor Control Kit with S32K144
https://www.nxp.com/docs/en/application-note/AN12235.pdf
2,422 次查看
종찬박
Thank you for reply.
I have another question.
In the document to attach, It use 2 ADC for measurement current.
If I want to measure another one (ex:Battery Voltage, Sensor Voltage),
Could I measure voltage using ADC?
Could I set another PDB Configuration for ADC?
2,417 次查看
danielmartynek
This is an application issue.
But in general, you can add other PDB - ADC channels.
BR, Daniel
