Dear support,
I did some tests and observed a difference between S32K144 and S32K146 behavior when trying to attach to running target (without flashing the elf file).
-> S32K144 SETUP Debug configurations
uncheck “Load executable” and check “Attach to Running Target”
If I use this settings for S32K146 the debug session does not start – it stuck somewhere and the debug session window does not appear …
After I uncheck the “Attach to target” in above window I’m able to connect to S32k146 and debug session stops at main right at the beginning.
Would be good to know the reson for teh differenc ebetween S32K144 and S32K146 with regards to this behavior …
Viktor
