Hi NXP Team,
I am using S32K342 and SiUL2 ICU EIRQ29 for external interrupt trigger. The purpose is the trigger interrupt based on a external pulse comes to S32K342. I have configured ICU Measurement mode as MODE_SIGNAL_EDGE_DETECT and set to ICU_RISING_EDGE in EBTresos. But interrupt is not generated at the PTD13 pin. I have attached some of the configuration screenshot for reference. Kindly help to fix the issue.
Thanks in Advance,
bbaskii
Icu is working now after verified the configuration carefully. You can close this ticket now.
Thanks for your support.
bbaskii
Hello @bbaskii,
Could you send me your configuration files (Icu.xdm, Port.xdm and Platform.xdm)?
Dan
