S32K CSEC M1 to M3
S32K CSEC M1 to M3
wanglijun
When calculating the M1 to M3, there is a parameter "key updated counter".
If the key update counter is wrong, can the key be loaded successfully?
lukaszadrapa
the answer is no. This behavior is required by SHE specification, it adds protection against replay attacks.
Lukas
wanglijun
Hello, Do you mean the input parameter key update counter must be equal to the actual key updated counter, if the 2 value is not equal, the key update not successfully, right?
lukaszadrapa
No, new counter needs to be incremented (+1). Initial value of the counter is 0 (this is given by SHE, considering new device or device reset to factory state). When you are going to load the key first time, you use counter = 1. When you are going to update the key second time, use counter = 2 and so on. If you do not follow this rule, the key won't be updated.
Lukas
wanglijun
Hello, Thank you for the reply. Can you share that how to prevent replay attach by the counter? Thank you!
lukaszadrapa
There's nothing to share, implementation of the counter itself is the protection.
Lukas
