S32DS using PE how to download the HEX file into the S32K3?
1,260 次查看
liyongfeng
I need to use PE to download HEX files directly into mcu. How to implement it?
Is this the right?
1,244 次查看
VaneB
Hi @liyongfeng
Please refer to the following post:
How to download hex file.
Also, if you do not want to use the IDE, there are other ways to download the hex file directly to the MCU. This topic has been already discussed in the PE Micro forum.
Software utility for downloading hex/bin file to K32l2a41 device using multilink universal programme...
I also recommend you contact PE Micro support since you are using their product.
B.R.
VaneB
1,210 次查看
liyongfeng
Thank you!
标记 (1)
