S32DS for Arm 2.2 : Unexpected status of script: Beans\lpspi\Items\S32K144_SDK01\lpspi_version.chg
已解决
跳至解决方案
1,554 次查看
lc12138
I use the Arm 2.2 open a demo object and want to debug it.
and then I get this:
Unexpected status of script: Beans\lpspi\Items\S32K144_SDK01\lpspi_version.chg, please contact Freescale support.
how could i solve this?
thanks.
1 解答
1,540 次查看
lukaszadrapa
not really sure what happened. Have you tried to clean the project, click on the "Generate Code" in PE and then compile the project again?
Or if you create the project again, can you still see the problem?
Lukas
在原帖中查看解决方案
2 回复数
1,541 次查看
lukaszadrapa
Lukas
1,532 次查看
lc12138
thanks a lot, I try to import a same project, and it says I may choose a wrong SDK path, when I change it to a right path, the error disappeared.
