S32D ARM 2.2 flexcan example didn't work on S32K116 EVB
yu_vincentcy
I need to implement some application on S32K116. Hence I chose File->New->S32DS project from example->S32DS Example Projects for S32K1XX->S32K116_Project->S32K116_Project_FlexCan to practice CAN communication. I tested it on S32K116 EVB - REV B but I didn't get any message by using CAN adapter (This tool is workable) with 500K baud rate. And S32K116 didn't get any CAN message sending from CAN adapter with ID 0x511.
I used usb for debugging and power supply. I wonder if this will cause voltage too low to push CAN device. Does anyone can help me? Thank you very much.
Vincent Yu
Omar_Anguiano
Hello Vincent Yu
I suggest you to use the latest S32DS release as well the latest SDK. Here you can get the latest S32DS: https://www.nxp.com/design/software/development-software/s32-design-studio-ide/s32-design-studio-for...
And the latest SDK version can be found here: https://www.nxp.com/design/software/development-software/s32-sdk/s32-software-development-kit-for-s3...
Let me know if this is helpful, if you have more questions do not hesitate to ask me.
Omar
yu_vincentcy
Thanks for your advice. This question is solved when i used 12V adapter.
