S32144 combined PWM, PWM
rangarajan_arum
we are using S32144 for combined PWM generation, and our PWM frequency is 1.25 Hz
we needs to sync the PWM register immediately instead of next loading point.
issue we are facing in immediate update configuration
PWM is not updating proper while refreshing the Duty in every 10ms.
Please suggest configuration to update proper PWM duty in every 10ms? while using immediate update
Next loading point is working fine, but its taking 800ms to update the new Duty
danielmartynek
Can you please elaborate on what exactly does not work properly?
Thank you,
BR, Daniel
