S32 Design studio V3.4. Project Import from other location to S32 DS workspace location.
284 次查看
Bholenath01
cc1.exe: error: could not open dump file  ......c.000i.type-inheritance': No such file or directory
Above is the build error I'm gettig can you please help me to solve?
标记 (1)
1 回复
241 次查看
Senlent
Hi@Bholenath01
Please describe your problem in detail
1. The RTD and IDE versions used by the project you are currently importing
2. The specific steps for your import
3. Are the IDE and RTD versions you are currently using consistent with the version used by the imported project?
