S32 3.5 Port not showing
Luzi
I am working with S32K144 and started working with S32K3. Port not showing in Debug Configuration. Verify the software i have already installed. And recommend GCC compiler version and SDK version which support S32K144 and S32K344.
Already installed software
Kindly give solution as soon as possible.
Senlent
Hi@Luzi
I see no problem with your installed software package.
you can click Select Device and try again.
Luzi
Not showing anything in select target device
Senlent
Hi@Luzi
1.Download S32 DS IDE.
https://nxp.flexnetoperations.com/control/frse/product?entitlementId=662026487&lineNum=1&authContact...
2.Run as Administrator to install S32 Design Studio V3.5 Windows installer.
Note1:
Your License Keys can be found in the highlight part.
Note2:Click “I Agree” to Install P&E Device
After I installed the IDE, no other plug-ins were installed, but I can still see the following configuration.
So I doubt whether you installed Note2(Install P&E) correctly during the installation of the IDE.
Luzi
issue still not resolved.
toolchain error showing.
Senlent
Hi@Luzi
Where did you get the demo? Have you tried or used the routines that come with the IDE?
Senlent
Hi@Luzi
I will try to re-install it from begining and record every steps, it will take time to reproduce your problem.
Luzi
Thanks for the reply
How to locate the 3.5 software mentioned in above screenshot(S32 Design studio for S32 platform) in NXP community?
I couldn't find in NXP community. Waiting for your reply.
Senlent
Luzi
Thank you for your reply
I have Installed the software as you told. but issue remain same.
Can you mention the software need to be installed in following page
waiting for your reply
Luzi
I am using S32K1xx Reference manual(S32K1xx Series Reference Manual, Rev. 13, 04/2020).
Kindly send the latest updated version.
Thank you.
Senlent
Hi@Luzi
please crate a new topic for your new question, thanks for your understanding.
https://www.nxp.com/products/processors-and-microcontrollers/s32-automotive-platform/s32k-auto-gener...
Luzi
I am using S32K1xx Reference manual(S32K1xx Series Reference Manual, Rev. 13, 04/2020). Kindly send the latest updated version.
Thank you.
