Removing symbol information in '.a' file
已解决
跳至解决方案
1,235 次查看
kmh48301
Hello.
I made '.a' file from s32ds ide (s32ds library project)
Now i need to remove symbol information in made '.a' file.
Changing makefile or changing project property might be solution...
(I prefer the way changing project property)
But I don't know.
Please help me
Best Regards
Phillip
1 解答
1,221 次查看
stanish
Hi Phillip,
If you have a separate library project I'd suggest you to switch off the debug information in the project properties -> compiler settings and rebuild the library.
Hope it helps.
Stan
在原帖中查看解决方案
1 回复
1,222 次查看
stanish
Hi Phillip,
Hope it helps.
Stan
