Register values are not showing in the memory - S32K388
1,176 次查看
Kiran_Gowda
Hi All,
I don't see any register values in the memory in the Lauterbach(LB) (i.e., MSCM base address + offset: 4026_0018h (Processor x Configuration 3 (CPXCFG3))).
Thanks in advance for your support.
3 回复数
1,107 次查看
Kiran_Gowda
Hi Daniel,
I am able to see the values for other registers, except the one starting with CPX, as shown below.
Thank you
1,058 次查看
danielmartynek
Hi Kiran,
I see, thank you.
This is specified in Table 37:
BR, Daniel
1,128 次查看
danielmartynek
Hi @Kiran_Gowda,
Can you read any other registers?
What do you see in the peripherals view?
Please be advised that customers who have been granted early access to NPI products, such as the S32K388, have assigned their field engineers. Your designated field engineer should serve as your primary support channel for any issues, concerns or queries you may have about this product.
