Possible to Erase/Sanitize all memory while running?
722 次查看
m_mishrikey
We are using an S32K148, and our customer has a requirement that the device be able to sanitize all volatile and non-volatile memory upon command, while in operation (no debugger or programmer, should wipe itself).
Is there a way to do this without a bootloader?  We presently do not have a bootloader, and using one would add significant complexity.
681 次查看
danielmartynek
Hello @m_mishrikey,
Volatile memories are reinitialized after every reset.
Non-volatile memories can be erased by sectors from the FTFC controller.
Except for the EEE backup. The FlexNVM should be pertitioned only once in the life time of the device.
I'm not sure I understand this use case, can you eleborate on the description?
677 次查看
m_mishrikey
I think it's either trade secret protection,  or an extreme cybersecurity requirement.   Like in the TV cartoon Inspector Gadget - "This message will self destruct in 5 seconds..."
