Porting Application software from s32k144 to S32k142.
581件の閲覧回数
Abhi_
I found a application software for S32k144 from https://www.nxp.com/docs/en/application-note-software/AN12323SW.zip. But I have a S32k142. So, I was trying to port the contents for S32k142. I could find a Q/A for a similar question, but the answer provided in the post seemed a bit outdated (was posted in 2018) and was not helping since the UI has changed a lot since then.
Does anyone know how to port the application project from S32K144 to S32K142 in Design Studio?
Thank you for the response.
タグ(2)
571件の閲覧回数
VaneB
Hi @Abhi_
If you are using any of the S32DS versions that have Processor Expert, you can check out the following post.
HOWTO: Change the CPU Derivative in an SDK-Based Application Project
Otherwise, changing from S32K144 to S32K142 in the latest S32DS versions is not possible. The most viable option is to generate a new project with the corresponding MCU and then copy the application source files from your pre-existing project as well as any customizations made to the project properties according to the device specifications.
B.R.
VaneB
2 返答(返信)
572件の閲覧回数
VaneB
Hi @Abhi_
B.R.
VaneB
542件の閲覧回数
Abhi_
Thank you @VaneB
