在官方样例Pwm_example_S32K344中,当配置全局变量中ComponentGenerationMethod参数的值为FunctionalGroups时,此时DefaultFunctionalGroup默认不能选择,编译可以正常通过。但将ComponentGenerationMethod参数的值改为EcucPostBuildVariants时,此时更新源代码,再次编译会出现下列图片中的错误,不知有没有解决方案,亦或是该问题可能是编译器的自身bug?除此样例工程外,尝试自行搭建工程也出现了同样问题。
目前采用的软件版本如下
hi, SUBUWL
Further information. Commonly, this feature is used in the multi-core system. If you are using the S32K344, you can disable the partition& PostBuildVariant feature.
HI, SUBUWL
Sorry, missed this ticket. This error is a software bug, we will process it asap, thanks for your feedback.
