PMC&CMU Error Injection
3,351 次查看
Pusoy
Recently, I have been using the PMC and CMU modules, but I haven't found a way to inject related exceptions to validate my program logic.
1. For the PMC module, is there a way to inject voltage exceptions? (such as injecting high or low voltage exceptions for VDD_HV_A)
2. For the CMU module, is there a way to inject frequency exceptions? (such as injecting high or low frequency exceptions for CMU_FC0)
Thank you very much!
标记 (4)
3,232 次查看
petervlna
No PMC nor CMU injection is possible here. Nor required.
This is all covered by SAF:
refer to safety manual for more details.
Peter
4 回复数
3,312 次查看
petervlna
on certain microcotrollers there is, but please specify the device you are using.
Peter
3,250 次查看
Pusoy
I have a development board based on the S32K344 chip, with the model S32K3x4_HDQFP172, as shown in the picture below.
Additionally, I also have a chip S32K312. 
1. Can these two devices inject PMC&CMU errors? If so, please provide the methods.
Thank you very much, I am looking for your replay!
3,233 次查看
petervlna
Peter
3,310 次查看
Pusoy
I am using S32K344 MQFP172
