May I get S32K1's FW from board?
jingfang
My client wants to check whether there is software in the chip of S32K1.
He has pe tool.
davidtosenovjan
Sure, you need to be attached by debugger.
Then follow following instruction:
https://community.nxp.com/t5/S32K/Getting-codeflash-dump-in-S32K/td-p/1094006
davidtosenovjan
Hi, do you need to upload the code from MCU or you just need to check whether MCU is blank or not. If only check, then just open memory dump window in the debugger and see its content.
jingfang
just want to check.
If there's no fw, memory can link?
davidtosenovjan
