Maximum Baud Rate for LPSPI in S32K146
DineshChandra
Maximum operating range of Baud rate in LPSPI communication for S32K146
VaneB
Hi @DineshChandra
The LPSPI baud rate depend on the module configuration. There is a function called LPSPI_SetBaudRate which returns the LPSPI baud rate in bits per second. This function you can find it S32K1xx SDK RTM v4.0.2.
Also refer to Table 46. LPSPI electrical specifications in the S32K1xx Data Sheet.
I hope this will help you.
B.R.
VaneB
