Hello All,
I have a problem with the NXP S32K146 board. When I want to use the mass erase with iSystem IC5700 debugger, I always got an error message that the Flash Operation Failed. I checked the registers and it seemingly everything is set that we should use the mass erase. Has anyone encountered this kind of problem?
Thank you in advance,
Marcell
Hi @marcellrigo
isn't the CSEc enabled? In this case, the Erase All Blocks command cannot be executed and it is necessary to destroy the partition as a first step:
Lukas
