MUX_0_CSC only use FIRC clock?
783 次查看
malove
While referring to the document on generating clocks for the S32K314, I came across a question.
[Figure1]
In [Figure1], it states that MUX_0_CSC receives either PLL_PHI0_CLK or FIRC_CLK as its input.
[Figure2]
However, in [Figure2], the explanation for the SELCTL bit of MSC_0_CSC only indicates that FIRC can be selected.
So, does this mean that MUX_0_CSC cannot use PLL_PHI0_CLK as a clock source?
标记 (2)
756 次查看
Senlent
Hi@studyseok8466
Please refer to latest datasheet , "S32K3xx Reference Manual, Rev. 9, 07/2024".
757 次查看
Senlent
Hi@studyseok8466
751 次查看
malove
thank you!
