MCU goes in continuous running state after flashing software with S32K MCAL(4.3.1 RTM1.0.5))
BhoneA
We have configured GPT and initialize clock, required peripherals as per integration manual.
I am facing an issue after flashing software with MCAL (4.3.1 RTM1.0.5).
As shown in below image, In the function Gpt_Lpit_Init , MCU goes in continuous running state after the instruction (highlighted at line 300), which is initializing module 0, Channel 1.
Please find the attached ARXML files for GPT, MCU, RESOURCE, BASE for your reference.
In addition to this, also log for peripherals registers PCC, RCM, Port, LPIT0 are attached.
Please let us know your response to troubleshoot this issue.
lukaszadrapa
Hi @BhoneA
Could you please create new ticket here?
https://support.nxp.com/s/?language=en_US
Then it will be moved to regional FAE team assigned to support your company.
Thanks for understanding.
Lukas
BhoneA
As per your request, I have created a ticket using the link you provided.
Ticket Number: 00701690 — for your reference.
lukaszadrapa
Thank you. I can see it was already moved to the right box.
