MCAL S32k314 integration
4,664 次查看
sanztr12
After integrating MCAL for S32K314_172MAXQFP  "SW32K3_RTD_4.4_1.0.0_P02_D2111.exe" I get the following error, anyone know how to fix this?
ERROR 21-12-02,02:12:04 (1806) The XPath-expression "ecu:get('MCU.ExtClock.Limits.EMAC_MII_RMII_TX_CLK')" caused an error: (35016) Cannot get a resource file for target CORTEXM and derivate S32K3XX. Maybe this is due to module restrictions.
ERROR 21-12-02,02:12:04 (1806) The XPath-expression "ecu:get('MCU.SXOSC.Limits.XTAL.High')" caused an error: (35016) Cannot get a resource file for target CORTEXM and derivate S32K3XX. Maybe this is due to module restrictions.
ERROR 21-12-02,02:12:04 (1032) Value "1" of node "/AUTOSAR/TOP-LEVEL-PACKAGES/ActiveEcuC/ELEMENTS/Mcu/McuModuleConfiguration/McuRamSectors" is out of range: The value for the McuRamSector must match with the McuRamSectorSettingConf. For calculating the correct value use the CALCULATE button
ERROR 21-12-02,02:12:04 (1806) The XPath-expression "ecu:get('MCU.FXOSC.Limits.XTAL.Low')" caused an error: (35016) Cannot get a resource file for target CORTEXM and derivate S32K3XX. Maybe this is due to module restrictions.
ERROR 21-12-02,02:12:04 (1803) Invalid XPath-expression for Attribute "INVALID" of node "/AUTOSAR/TOP-LEVEL-PACKAGES/ActiveEcuC/ELEMENTS/Mcu/McuModuleConfiguration/McuClockSettingConfig/McuClockSettingConfig/McuClkMonitor": (35016) Cannot get a resource file for target CORTEXM and derivate S32K3XX. Maybe this is due to module restrictions.
"/AUTOSAR/TOP-LEVEL-PACKAGES/ActiveEcuC/ELEMENTS/Port/PortConfigSet/PortContainer/PortContainer/PortPin/PortPin_PTB22_CAN1_RX/PortPinSiul2Instance": (35016) Cannot get a resource file for target CORTEXM and derivate S32K3XX. Maybe this is due to module restrictions.
ERROR 21-12-02,02:12:04 (1803) Invalid XPath-expression for Attribute "RANGE" of node "/AUTOSAR/TOP-LEVEL-PACKAGES/ActiveEcuC/ELEMENTS/Port/PortConfigSet/PortContainer/PortContainer/PortPin/PortPin/OBEGroupSelect": (35016) Cannot get a resource file for target CORTEXM and derivate S32K3XX. Maybe this is due to module restrictions.
ERROR 21-12-02,02:12:04 (1806) The XPath-expression "num:i(ecu:list('Port.Siul2MaxNumConfiguredMscrs')[1])" caused an error: (35016) Cannot get a resource file for target CORTEXM and derivate S32K3XX. Maybe this is due to module restrictions.
ERROR 21-12-02,02:12:04 (1803) Invalid XPath-expression for Attribute "RANGE" of node "/AUTOSAR/TOP-LEVEL-PACKAGES/ActiveEcuC/ELEMENTS/Port/PortConfigSet/PortContainer/PortContainer/PortPin/PortPin_PTB18_CAN_FD_STB_Q/PortPinSiul2Instance": (35016) Cannot get a resource file for target CORTEXM and derivate S32K3XX. Maybe this is due to module restrictions.
ERROR 21-12-02,02:12:04 (1803) Invalid XPath-expression for Attribute "RANGE" of node "/AUTOSAR/TOP-LEVEL-PACKAGES/ActiveEcuC/ELEMENTS/Port/PortConfigSet/PortContainer/PortContainer/PortPin/PortPin/PortPinMode": (35016) Cannot get a resource file for target CORTEXM and derivate S32K3XX. Maybe this is due to module restrictions.
ERROR 21-12-02,02:12:04 (1806) The XPath-expression "num:i(ecu:list('Port.Num16PinsBlocks')[1] * 16)" caused an error: (35016) Cannot get a resource file for target CORTEXM and derivate S32K3XX. Maybe this is due to module restrictions.
ERROR 21-12-02,02:12:04 (1803) Invalid XPath-expression for Attribute "RANGE" of node "/AUTOSAR/TOP-LEVEL-PACKAGES/ActiveEcuC/ELEMENTS/Port/PortConfigSet/PortContainer/PortContainer/PortPin/PortPin_PTB18_CAN_FD_STB_Q/PortPinMode": (35016) Cannot get a resource file for target CORTEXM and derivate S32K3XX. Maybe this is due to module restrictions.
ERROR 21-12-02,02:12:04 (1803) Invalid XPath-expression for Attribute "RANGE" of node "/AUTOSAR/TOP-LEVEL-PACKAGES/ActiveEcuC/ELEMENTS/Port/PortConfigSet/PortContainer/PortContainer/PortPin/PortPin_PTB22_CAN1_RX/PortPinMode": (35016) Cannot get a resource file for target CORTEXM and derivate S32K3XX. Maybe this is due to module restrictions.
ERROR 21-12-02,02:12:04 (1803) Invalid XPath-expression for Attribute "RANGE" of node "/AUTOSAR/TOP-LEVEL-PACKAGES/ActiveEcuC/ELEMENTS/Port/PortConfigSet/PortContainer/PortContainer/PortPin/PortPin_PTB23_CAN1_TX/PortPinMode": (35016) Cannot get a resource file for target CORTEXM and derivate S32K3XX. Maybe this is due to module restrictions.
ERROR 21-12-02,02:12:04 (1803) Invalid XPath-expression for Attribute "RANGE" of node "/AUTOSAR/TOP-LEVEL-PACKAGES/ActiveEcuC/ELEMENTS/Port/PortConfigSet/PortContainer/PortContainer/PortPin/PortPin_PTB22_CAN1_RX/OBEGroupSelect": (35016) Cannot get a resource file for target CORTEXM and derivate S32K3XX. Maybe this is due to module restrictions.
ERROR 21-12-02,02:12:04 (1803) Invalid XPath-expression for Attribute "RANGE" of node "/AUTOSAR/TOP-LEVEL-PACKAGES/ActiveEcuC/ELEMENTS/Port/PortConfigSet/PortContainer/PortContainer/PortPin/PortPin_PTB23_CAN1_TX/OBEGroupSelect": (35016) Cannot get a resource file for target CORTEXM and derivate S32K3XX. Maybe this is due to module restrictions.
ERROR 21-12-02,02:12:04 (1803) Invalid XPath-expression for Attribute "RANGE" of node "/AUTOSAR/TOP-LEVEL-PACKAGES/ActiveEcuC/ELEMENTS/Port/PortConfigSet/PortContainer/PortContainer/PortPin/PortPin_PTB23_CAN1_TX/PortPinSiul2Instance": (35016) Cannot get a resource file for target CORTEXM and derivate S32K3XX. Maybe this is due to module restrictions.
ERROR 21-12-02,02:12:04 (1803) Invalid XPath-expression for Attribute "RANGE" of node "/AUTOSAR/TOP-LEVEL-SW32K3_RTD_4.4_1.0.0_P02_D2111.exePACKAGES/ActiveEcuC/ELEMENTS/Port/PortConfigSet/PortContainer/PortContainer/PortPin/PortPin_PTB18_CAN_FD_STB_Q/OBEGroupSelect": (35016) Cannot get a resource file for target CORTEXM and derivate S32K3XX. Maybe this is due to module restrictions.
INFO 21-12-02,02:12:04 (2164) Verify module configuration "/ActiveEcuC/Mcu"
INFO 21-12-02,02:12:04 (2164) Verify module configuration "/ActiveEcuC/Dio"
INFO 21-12-02,02:12:04 (2164) Verify module configuration "/ActiveEcuC/Port"
Errors "518" Warnings "325"
3 回复数
4,481 次查看
muellermathias
I don't know if this still is relevant. If yes, you could try the solution mentioned in https://community.nxp.com/t5/S32K/EB-Tresos-error-when-configuring-MCAL-RTD-components-with-Vector/m...
4,583 次查看
Guofred
Hi @sanztr12 ,
I'm not sure your software compile environment is ok or not, Small ideas for you reference, thanks.
EB Tresos Studio 27.1.0
-- MCAL configuration tool.
S32 Design Studio 3.4.1 track
-- INTEGRATED development environment (IDE) of NXP S32 series, which can be used for project creation, configuration, compilation, debugging, etc.
SW32K3_RTD_4. 4 _1. 0.0 _D2110. Exe
S32K3 RTD installation package, using EB Tresos Studio for configuration.
SW32K3_S32DS_3. 4.1 _D2110. Zip
-- RTD base development kit for S32DS S32K3.
Best regards.
Guofred
4,595 次查看
4AJ
Facing same error on S32K314 with same version of RTD. Please let me know solution if this issue is resolved.
