MC33771C Register Description
Knc5
Hi Community,
Regarding the above subject, I am requesting for the register's descriptions document of MC33771C battery cell controller. I have a datasheet, in that registers are not described. I need technical reference manual, where detailed description of registers will be provided normally. Where can I get that document?
Kindly do the needful.
Thanks in advance.
TomasVaverka
Hi Karthik,
I assume you only have the product brief that indeed does not include a description of the registers.
The MC33771C datasheet rev. 6 provides register descriptions in chapter 11. This datasheet is classified as a secure file requiring an NDA.
If your company has not signed the NDA with NXP yet, you can request it from:
https://www.nxp.com/support/support:SUPPORTHOME
If there is a valid NDA in place, you can download the MC33771C datasheet from the following website:
https://www.nxp.com/products/power-management/battery-management/battery-cell-controllers/14-channel...
PS: Please make sure you are signed in to nxp.com. If you do not see the datasheet, please click on "Request additional access" or edit your secure access rights by going to My NXP > Profile. For more information about secure access rights, please refer to this website:
https://www.nxp.com/support/support/secure-access-rights:SEC-ACCESS
BR, Tomas
Knc5
Hi @TomasVaverka,
Thanks for your kind and quick response.
Yes, I have a product brief only.
The points you have mentioned are noted and will check the same.
Thanks, and best regards,
Karthik
TomasVaverka
Hi Karthik,
BR, Tomas
