Lin_Slave_S32K118_Example_DS compile error
268 次查看
LJX
hi,
I installed S32DS V3.6.2 250529 (Update 2),  SW32K1_S32M24x_RTD_R21-11_3.0.0_D2503_DesignStudio_updatesite.zip and SW32K1_S32M24X_LIN_STACK_2.0.0_D2503_DesignStudio_updatesite.zip.
Then i import Lin_Slave_S32K118_Example_DS, we can see some head files are missing, detail please see the attachment "compiler error.txt".
I tried to search these files in "C:\NXP\S32DS.3.6.2", and added in compile path:
but still will report mcu.h -> Mcu_Cfg.h compiler "[!" error:
Q1: Please help to check is environment problem?
Q2: I try to set LIN stack configuration in S32DS, then port the LIN code to my keil compile environment, can you give some advise?
215 次查看
Senlent
Hi@LJX
Have you try to click Update code before compile project?
203 次查看
LJX
I try to update the source code, then i will get error:
LIN Stack document show support S32DS V3.6, but now I use S32DS V3.6.2, so this is S32DS version problem?
196 次查看
Senlent
Hi@LJX
Judging from the error in your screenshot, you haven't installed RTD and LIN STACK properly. Please double-check your installation.
For example, you can try opening some of the examples provided with RTD.
