I would like to interface an SD card reader via SPI from an S32K116.
Now I wondered, is there some library available, hopefully including file system handling aso?
Volker
Thanks Alexis, I'll try that. I was aware of http://elm-chan.org/fsw/ff/00index_e.html but getting an example for the lower layer is a big help.
Volker
Hello Volker,
Unfortunately for this particular MCU is not available but you could try checking the following thread that mentions a driver for other MCU:
https://community.nxp.com/docs/DOC-330958
Alexis Andalon
