LPUART_RS485
LPUART_RS485
2,738 次查看
intern_praveena
I am doing uart tx and rx using RS485,In that i can able to tx and rx but in putty entering char is not displayed.What is the problem??like if i press 'a' its receiving in debug session , but it not dispalyed in putty.
5 回复数
2,345 次查看
intern_praveena
thanks , but if i use LPUART_RECVE function in driver code then only receiving data is working . if i remove that function in driver code only in main function its not working.
2,345 次查看
PetrS
what is the SDK version you use? I would strongly recommend to use the latest one.
BR, Petr
2,345 次查看
intern_praveena
I m using S32SDK_S32K14x_EAR_0.8.6 (S32K144_64)
2,345 次查看
PetrS
you need to enable local echo within terminal tool or you should send receive byte back to display it on terminal window.
Regarding LPUART_DRV_IRQHandler; seems you are using some older SDk version as in the latest SDK RTM 3.0.0 the LPUART_DRV_ReceiveData is not called from interrupt.
BR, Petr
2,345 次查看
intern_praveena
why LPUART_RECEIVE function is also used in driver code,what is the reason???
void LPUART_DRV_IRQHandler(uint32_t instance)
DEV_ASSERT(instance < LPUART_INSTANCE_COUNT);
lpuart_state_t * lpuartState = (lpuart_state_t *)s_lpuartStatePtr[instance];
LPUART_Type * base = s_lpuartBase[instance];
/* Exit the ISR if no transfer is happening for this instance. */
if (!lpuartState->isTxBusy)
if (!lpuartState->isRxBusy)
return;
/* Handle receive data full interrupt */
if (LPUART_GetIntMode(base, LPUART_INT_RX_DATA_REG_FULL))
if (LPUART_GetStatusFlag(base, LPUART_RX_DATA_REG_FULL))
/* Invoke callback if there is one */
if (lpuartState->rxCallback != NULL)
lpuartState->rxCallback(lpuartState, UART_EVENT_RX_FULL, lpuartState->rxCallbackParam);
else
/* Get data and put in receive buffer */
LPUART_DRV_GetData(instance);
/* Update the internal state */
if (lpuartState->bitCountPerChar == LPUART_8_BITS_PER_CHAR)
++lpuartState->rxBuff;
--lpuartState->rxSize;
else
lpuartState->rxSize -= 2U;
/* Finish reception if this was the last byte received */
if (lpuartState->rxSize == 0U)
/* Complete transfer, will disable rx interrupt */
LPUART_DRV_CompleteReceiveDataUsingInt(instance);
LPUART_DRV_ReceiveData(1,&rxbuff,1);
/* Handle transmitter data register empty interrupt */
if (LPUART_GetIntMode(base, LPUART_INT_TX_DATA_REG_EMPTY))
if (LPUART_GetStatusFlag(base, LPUART_TX_DATA_REG_EMPTY))
/* Check if there are any more bytes to send */
if (lpuartState->txSize > 0U)
if (lpuartState->txCallback != NULL)
lpuartState->txCallback(lpuartState, UART_EVENT_TX_EMPTY, lpuartState->txCallbackParam);
else
/* Transmit the data */
LPUART_DRV_PutData(instance);
++lpuartState->txBuff;
--lpuartState->txSize;
else
lpuartState->txSize -= 2U;
/* Finish the transmission if this was the last byte */
if (lpuartState->txSize == 0U)
/* Complete transfer, will disable tx interrupt */
LPUART_DRV_CompleteSendDataUsingInt(instance);
/* Handle receive overrun interrupt */
if (LPUART_GetStatusFlag(base, LPUART_RX_OVERRUN))
lpuartState->receiveStatus = STATUS_UART_RX_OVERRUN;
/* Clear the flag, OR the rxDataRegFull will not be set any more */
(void)LPUART_ClearStatusFlag(base, LPUART_RX_OVERRUN);
return;
else
else
else
else
return;
else
else
else
else
