Issue with the "Explore the board" part under FreeMASTER
jungx148
This is the first time to power up the S32K144_EVB using FreeMASTER.
My computer connects well with the S32K144_EVB but an issue comes up when I tried to process the "4.2 FreeMASTER JumpStart project download" shown in the following link.
https://www.nxp.com/document/guide/get-started-with-the-s32k144evb:NGS-S32K144EVB
When I tried section 4.2 in the above link, the following error popup comes up.
"Could not open project file from link: http://www.nxp.com/assets/downloads/data/en/application-software/S32K144EVB_OOBE.pmpx"
For your reference, I attached a capture of the warning popup in this thread.
Any help will be appreciated. Thank you very much.
Dr. Sunghun Jung
A. Dept. of Smart Mobile Convergence System, Chosun University,
Aerospace Engineering Building, #4103-1
309 Pilmun-daero, Dong-gu, Gwangju 61452, Republic of Korea
P. 062.230.7188
M. 010.9507.5806
E. jungx148@gmail.com / jungx148@chosun.ac.kr
Homepage. https://www.uaslaboratory.com/
MDPI Applied Sciences Special Issue (SCI, IF 2.474): https://www.mdpi.com/journal/applsci/special_issues/Technologies_UAVs
jungx148
I could be able to solve the issue by downloading a file from the following link and importing the file using FreeMASTER.
https://www.nxp.com/webapp/sps/download/preDownload.jsp?render=true
Dr. Sunghun Jung
P. 062.230.7188
M. 010.9507.5806
Anonymous
Deactivated User
I had the same problem.
I solved it by downloading S32K144_EVB_JumpStart_PC.zip
go on nxp.com > Design> Software, search for OOBE  and download
S32K144EVB Evaluation Board – Software for FreeMASTER (REV 1)
extract the file and execute S32K144_EVB_JumpStart.pmpx
jungx148
Dr. Sunghun Jung
P. 062.230.7188
M. 010.9507.5806
Robin_Shen
Hi jungx148,
Sorry for the inconvenience we bring you!
You can download the S32K144_EVB_JumpStart_Firmware.zip
attached in: Cannot Connect to S32K144 (Neither FreeMaster nor S32DS)
Robin
