Is there a register that indicates LIN bus off?
600 次查看
Kang111
Hi?
I'm using S32K144.
Or if you have any examples related to this, please let me know.
标记 (1)
3 回复数
565 次查看
danielmartynek
Hi @Kang111,
What do you mean by the BUS OFF?
The LIN bus is pulled to VBAT, so do you mean the bus is OFF if the bus is recessive for an some time?
554 次查看
Kang111
The LIN bus off state means that an error has occurred and normal communication is no longer possible.
It also means that the LIN connection has been disconnected in hardware!
标记 (1)
535 次查看
danielmartynek
Hello @Kang111,
There is no such register.
There is a LIN Tranceiver between the LIN BUS and the LPUART module of the S32K144.
The LPUART HW module is managed by the RTD LIN Driver / LIN Stack that can detect errors.
Detection of such a BUS OFF would need to be implemented in the user code.
