Is it possible to write any data to UTest area in SystemInit for S32K312
1,896件の閲覧回数
HyunungPark1
I want to write any data to UTest Area(for example : 0x1b000060) in SystemInit.
is it possible?
タグ(1)
1,776件の閲覧回数
petervlna
Security (HSE) topics are not discussed on public community.
Please submit a ticket at NXP.com for support on such theme.
Peter
7 返答(返信)
1,873件の閲覧回数
petervlna
In these areas you can store you information.
make sure in case you are using UTEST DCF Start or Records, to store your data after 0xFFFF_FFFF_FFFF_FFFF space from your DCf data.
Also be aware that storing data after stop record will leave you will no possibility to add additional DCF records. So leave enough space.
Peter
1,838件の閲覧回数
HyunungPark1
In additional,
Is it possible to write the attached file to 0x1b000000 using MCU Programming Tool like FR-Cube
without running code for hse enable?
BRs.
Hyunung Park
タグ(1)
1,823件の閲覧回数
petervlna
There is no restriction o n programming UTEST. It is just a normal flash which is set as OTP in NXP factory.
Follow the procedure described in reference manual for UTEST programming.
chapter 21.3 UTest NVM sector
MCU Programming Tool like FR-Cube without running code for hse enable?
Unfortunate I do not know your FR-Cube tool. Please consult such with your tool vendor.
Peter
1,795件の閲覧回数
HyunungPark1
Hi.
I make SHERPA_HSE_INSTALL_S32K312.sre file to install hse binary(s32k3x2_hse_fw_0.13.0_2.6.0_pb221129.bin.pink).
and Power off and on runs after I download this file.
But HSE Enable flag does not written to 0x1b000000.
Could you please let me know what is problem?
タグ(1)
1,777件の閲覧回数
petervlna
Peter
1,793件の閲覧回数
HyunungPark1
The attached file is the firmware to install hse firmware
タグ(1)
1,754件の閲覧回数
HyunungPark1
This issue is resolved.
タグ(1)
