We are planning to use SD card along with S32K144x MCU
Is there any generic library/code/test example with whose help we can implement the same
Hi Shubhendu Shukla
Unfortunately, S32K family doesn't have an SD module, so if you want to integrate a SDcard, you will need to create the drivers with LPSPI module. Sorry for the inconveniences that this may cause you.
Jorge Alcala
