Interfacing S32K144 WITH SD card module holding Sandisk 32GB micro SDHC SD card
746件の閲覧回数
Gayathri_Sankaramoorthi
http://www.rjhcoding.com/avrc-sd-interface-1.php
The above site mentioned about how to set SPI mode of SD card with flow chart. I followed the same and modified according to the s32k144 code. And micro SD card reader I mentioned earlier was Micro SD Card Reader Module..
http://elm-chan.org/fsw/ff/00index_e.html
The above site provided the resources as well as detailed FatFs - Generic FAT file system module.
The below site interfaced PIC microcontroller and SD card with the same resource file FatFs
https://circuitdigest.com/microcontroller-projects/save-and-store-data-in-sd-card-using-pic-microcon...
If i tried with the same resource inorder to create file and store data in it, ELF file not get generated. Facing linker issues. The SD card which i am using is formatted with fat32 file system.
Looking for solution. Please find the attached file. Thanks..
0 返答(返信)
