Installation error of “S32 Design Studio for Platform
toru88
An installation error occurs when installing “S32 Design Studio for Platform 3.5.0” after installing “S32 Design Studio for Platform 3.6.0”.
I entered a 3.6.0 code for the “Software Activation Code” during installation, but I get an error that the software is already activated at 3.6 on the “software_activation_code_error.png” screen.
When I enter the 3.5 license installed on another PC, the “software_activation_code_online.png” screen to select “online” or “offline” is displayed.
When I select “online”, an error occurs, and when I select “offline”, “request.xml” is requested, but there is no “request.xml” and installation cannot be performed.
When I cancel the installation, the “install_rollback.png” screen appears and the installation is aborted.
How can I install an older version of “S32 Design Studio for Platform”?
petervlna
There is version 3.6.1. which replacing 3.6.0. and it does not require activation key.
In case you need 3.6 version install 3.6.1. which is latest release.
In case you need to install 3.5. version your activation key is:
5BD2-2440-51F5-103D
Peter
